Unlevel Floor Under Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2006, 04:07 PM   #1
Question
Unlevel floor under laminate
Hey guys,
I'm getting ready to lay a floating floor in a kitchen which is about 9x10. However, I checked it with a 4 foot level an there is one joist that is between 1/4 and 1/2 inch high.
Can I run the laminate parrell with the joist to get the t&g to compensate for the joist?
Bandit is offline   Reply With Quote
Old 11-08-2006, 04:17 PM   #2
General Contractor
The floor needs to be level or the flooring will eventually come apart. You can either use a leveling compound or see why that one joist is sticking up and see if you can fix that.
Hammatime is offline   Reply With Quote
Old 11-08-2006, 04:22 PM   #3
Thanks Hammatime. That's what I was afraid of....
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 02:25 PM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 08:43 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
