Old 04-22-2011, 11:56 PM   #1
Unlevel Floor
I am tiling our masterbath floor with 18x18 porcelain tile. I have found that one edge of the room (about 2-3') slopes up by about 3/8". The rest of the room is pretty level. This is on a 2nd floor with plywood subfloor.
Any ideas on how to level this out?
I thought of using self leveling underlayment, but I figure I will be pouring it to about 5/8" thick once I add in the mesh. That's a lot of bags for a 100 sq ft room.
Thanks in advance for any ideas.
handyman923 is offline   Reply With Quote
Old 04-23-2011, 09:36 AM   #2
Unlevel Floor
What is the mesh for?
What are you putting this large tile over? Not directly on plywood I hope?
That size tile will require a very rigid floor system. What sort of joists do you have? Size, span and spacing.
Ron
Old 04-23-2011, 10:03 AM   #3
Unlevel Floor
The floor should be plenty stiff... 2x10's at 16"oc spanning 10'.
The mesh would be for applying the self leveling underlayment over a plywood substrate.
If I don't use the self leveling underlayment, I would use backerboard or Ditra over the plywood.
Thanks.
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Trying to install ceramic tile on unlevel floor in 1890's era house Kichigaidave Flooring 10 06-11-2010 01:43 AM
Tile over existing floor tile radient with electric heat brownieruf Off Topic 7 05-22-2010 07:49 PM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
