Unheated Cottage Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 05:10 PM   #1
unheated cottage floor
I just purchased a 30 year old unfinished cottage which has 2 layers of 3/8 chip board (is this the same as osb?). The cottage has been closed but not perfectly and the floor is squishy/wavey between the joists.
Can I just go over this floor with 3/4 ply or do I need to remove the existing floor and then try to fit 3/4 ply in (it won't be exact since the old flooring runs under the wall sill plates.
bobhawes is offline   Reply With Quote
Old 04-28-2013, 08:21 PM   #2
DIY staff
Rewards Points: 7,174
I suggest removing the old ,failing subfloor---use 3/4" bc (exposure 1) plywood--
Some will recommend Advantec sheeting---I haven't used it--but the water proof coating might be just what you need for a place that is unheated part of the year---
Wake up,Joe---I know you prefer that for floors----
Bridging--bouncy vibrating floor meature Building & Construction 15 02-05-2013 05:43 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
