Unfinished Wood How To Guides - Flooring - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 12:59 PM   #1
msaeger's Avatar
Rewards Points: 260
unfinished wood how to guides
Anyone have any good diy sites for installing unfinished wood flooring?
msaeger is offline   Reply With Quote
Old 11-15-2012, 02:12 PM   #2
is this regular 3/4 inch thick hardwood flooring?
let the wood acclimate in the area it will be installed in for a week
usually you start along the longest straight wall perpendicular to the floor joists.
start the first row perfectly straight and keep adding to it. you will need to trim door jambs and casing for the flooring to fit under.
you will need clearance along the walls at least 1/4- 1/2 inch. its easier if you remove the baseboards.
pictures of the area help greatly.
what the flooring in the adjacent rooms?
why unfinished? that's what i did in my house but i have did it numerous times over the years because i didnt like the bevels on the prefinished stuff.
if you aren't experienced in finishing floors i would use the pre-finished. once you nail the last piece in you are done.
The Following User Says Thank You to DannyT For This Useful Post:
joecaption (11-15-2012)
Old 11-15-2012, 05:57 PM   #3
msaeger's Avatar
Rewards Points: 260
I haven't totally decided what to get for sure. I am thinking unfinished because I wouldn't have to worry about damaging it so much during installation and I don't like the bevels.
The area is two bedrooms connected by a hallway on a second floor. I am thinking about either carpet in the bedrooms and wood in the hall or wood over the whole thing.
It's new and no doors or trim have been installed yet so that should make it easier.
Old 11-15-2012, 06:17 PM   #4
Rewards Points: 13,444
Go with the prefinished or at least engineered.
No smell, no sanding, walk on it the same day.
No having to move out until it drys.
Far longer lasting finish then a site job.
Old 11-15-2012, 06:55 PM   #5
DIY staff
Rewards Points: 7,174
You are right---the unfinished is faster and much more forgiving of errors---hiring a company to come and sand/ finish is usually quite reasonable----
One item many first timers are not aware of----SPLINES---this is a strip of wood that tucks into the groove and allows you to change your nailing direction---it turns the grove into a tongue----
Very handy with a hallway heading into bedrooms----
Old 11-15-2012, 07:51 PM   #6
msaeger's Avatar
Rewards Points: 260
What makes the finishing so hard? I was thinking finishing would be the easy part.
Old 11-15-2012, 08:10 PM   #7
Rewards Points: 944
There is a book by Bolinger, something like "Installing and caring for wood floors". I've done it myself. The installation is nothing special for a straightforward install. I bought a nailer which you whack with a mallet.
Wear gloves.
I rented a drum sander and an edger. I had a floor buffer which I put a screen on to screen in between coats of finish.
A central vac comes in handy to clean up. Vac the walls also after sanding. I think 3 coats of oil poly is the way to go, minimum. I'm always amazed when I'm finishing wood how long the first coat takes to dry compared with coats two and three.
Anyway, mine came out well. Read the book and diy. You'll be better because of it.
cleveman is offline   Reply With Quote
Old 11-15-2012, 09:33 PM   #8
The hard part of DIY is the type of equipment you can rent , And your lack of experience , but there are ways to deal with lack of experience , Read through here there are threads about installing hardwood ,Lay Light grade roofing felt under the hardwood ,Especially on a 1st story .Then get a floor sander and sand it off with 40 grit , Move up to 60 grit nd edge with 60 grit, Then use a ood floor filler , Home depot has it , Sand the filler off with 60 grit , Then fine sand with 100 ,Vibe sand the edges with 100 grit, The problem is the amount of time it will take you ,The way to fix the average DIY mistakes is to use several 100 grit buffer papers and buff The Heck out of it , The disk paper that goes on a buffer is stiff so it flattens the Dimples and edger marks that an begginer will make , Then Buff the heck out of it with a 120 screen , It would be risky for a DIY to use a dark stain , I would steer clear of stain , Unless you have to. Get started and post pictures as you go , People will help you
tacomahardwood. is offline   Reply With Quote
Old 11-15-2012, 09:33 PM   #9
msaeger's Avatar
Rewards Points: 260
This one?
http://www.amazon.com/Hardwood-Floor...or+wood+floors
Old 11-15-2012, 11:47 PM   #10
That's all the steps plus all the time for clean up, times for each layer to dry.
Installing a prefinished floor go's more like, install floor, walk on it.
Old 11-18-2012, 10:56 AM   #11
Agreed with Joecaption , This is not an extremely difficult job , But it will be easier to install pre finish. If you do not like to see the pre finish micro bevel lines then install sand and finish the floor
Old 11-18-2012, 06:55 PM   #12
Rewards Points: 264
Unfortunately, most of the how to sites I have come across are not very good. I agree with that book someone else recommended it seems to be the most popular how to book. I am in the process of creating some how to sites, I will try to remember to share them here when they are done.
Awoodfloorguy is offline   Reply With Quote
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 03:23 PM
2nd Remodel project question about attic WOOD KevRU Carpentry 18 04-12-2011 12:22 PM
how do i preserve wood slats subfloor? What can I put on top of the wood slats subfloor? l79gemini Flooring 1 12-17-2010 01:31 PM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 09:14 AM
