Old 09-15-2006, 11:18 AM   #1
Uneven wood floors
I have old wood floors I plan on refinishing but I suspect they are uneven. The question is do I concentrate the drum sander over the high spots until they're even with the rest of the floor?
Krichton is offline   Reply With Quote
Old 09-16-2006, 11:51 PM   #2
Middle aged floor guy
Donedat's Avatar
Uneven wood floors
Most drum sanders are designed to sand from left to right. You should get a DIY video from you rental supplier. The goal is to sand the floor flat, moving from the left side to the right. Feather up to the wall and feather the middle of the floor. Step sand by starting with 40g, 60, then final with 100. 60 and 120 on the edge sander. 120 with the buffer.
Donedat is offline   Reply With Quote
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Help Installing wood floors helpless handyman Carpentry 1 03-18-2007 08:46 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-17-2006 12:00 AM
Floating Wood Floors? dag Flooring 1 06-22-2006 10:40 PM
