Uneven Transition - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By MTN REMODEL LLC
Old 01-07-2017, 02:43 PM   #1
Rewards Points: 2
Uneven transition
We are at a transition in installing our laminate flooring and are unsure where to go from here. There is a brick tile floor in the next room that is laid unevenly, crossing the doorway at an angle. To put In the transition molding as the tile floor is would either leave a gap or would have a crooked transition piece.
Would evening the gap with mortar or with flooring leveler be a plausible solution?
Uneven transition-1483821442588-1405999956_1483821620772.jpg   Uneven transition-1483821639340-624320124_1483821663262.jpg   Uneven transition-1483821687316550708647_1483821734699.jpg
Pegowow is offline   Reply With Quote
Old 01-27-2017, 11:48 AM   #2
Designer
Rewards Points: 48
Re: Uneven transition
I think you are looking for a T Moulding or reducer strip.
They come in many shapes and sizes.
cdpage is offline   Reply With Quote
Old 01-27-2017, 12:09 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,786
If I understand correctly... isn't your store bought transition too narrow....?
I assume you have a floating floor and need a T transition... I think you need to pull out the table saw and cut a bigger custom transition.... either butting up to the brick or lapping both the brick and new flooring.
rjniles likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 01-28-2017, 12:28 PM   #4
Rewards Points: 954
Yup, make your own.
clarenceboddick is offline   Reply With Quote
Old 01-28-2017, 04:11 PM   #5
Rewards Points: 1,066
Prolly figured it out already since the post is couple weeks old now.. But yes or cut the brick.. angle grinder makes lots of dust but will do the job..
Why is that piece of flooring so far from the brick?
ryansdiydad is offline   Reply With Quote
Baseboard Transition svaic00 Flooring 10 10-03-2014 08:13 AM
transition to uneven rustic slate fireplace Marusha Flooring 1 07-28-2011 03:59 PM
Uneven hw floor to vinyl transition joemontana16 Flooring 0 03-10-2010 10:10 AM
Uneven floor transition between bath and hallway geneman100 Kitchen & Bath Remodeling 3 02-23-2010 07:31 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
