Old 07-06-2012, 08:34 PM   #1
uneven subfloor particle board
how do i feel in space on warped subfloor
stevetanuz is offline   Reply With Quote
Old 07-06-2012, 08:38 PM   #2
JetSwet's Avatar
Need way more info then that, don't be shy let us know what's up and what your plan is, how it got like that.
JetSwet is offline   Reply With Quote
Old 07-06-2012, 10:46 PM   #3
Are you 100% sure it's even partical board and not OSB? Totaly differnt materails.
Partical board looks like compressed saw dust and is no longer an exceptable subfloor. If it gets wet once or there's rising moisture from under the subfloor it turns to oatmeal and is useless.
If it is partical board cut it all out and replace it with 3/4" Advantec T & G subflooring glued and screwed to the floor joist for a subfloor that will be level, far more moisture resistant and will be flat.
Base board has uneven heat wot70 Plumbing 2 02-19-2012 09:23 AM
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
uneven hardy board joints after taping Jt12 Flooring 1 11-19-2011 06:14 PM
