-   -   uneven subfloor particle board (http://www.diychatroom.com/f5/uneven-subfloor-particle-board-149410/)
stevetanuz 07-06-2012 07:34 PM
how do i feel in space on warped subfloor
JetSwet 07-06-2012 07:38 PM
Need way more info then that, don't be shy let us know what's up and what your plan is, how it got like that.
joecaption 07-06-2012 09:46 PM
Are you 100% sure it's even partical board and not OSB? Totaly differnt materails.
Partical board looks like compressed saw dust and is no longer an exceptable subfloor. If it gets wet once or there's rising moisture from under the subfloor it turns to oatmeal and is useless.
If it is partical board cut it all out and replace it with 3/4" Advantec T & G subflooring glued and screwed to the floor joist for a subfloor that will be level, far more moisture resistant and will be flat.
