Uneven Sub-floor Issue In Basement - SOLUTIONS? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 07:52 PM   #1
Uneven sub-floor issue in basement - SOLUTIONS?
Hi there:
My wife and I have a back entry area in our basement. It is 24' by 10' and we are planning on putting down a vinyl floor and using at a mud room/storage space.
In the past someone had vinyl down and most of it has come up and there is a little more that needs to be taken up. Under that are square tiles, i think, that appear to be acting as a subfloor. I do not know what is under neath these tiles, though I would imagine that it is poured cement.
I would just put the vinyl over the top of this tile except for one problem, near the entry door, the floor is raised about 1/3" -1/2". A picture of the tile and the raise area are attached.
So the question is this - what are my options?
On one hand I wonder if I can just put down and underlayer that would bring everything up to the same level as the raised area and then put vinyl over that.
On the other hand, i think I could pull up the tiles and lay the vinyl down right on the concrete floor. However, this doesnt mean that I the cement base its also raised in that area. So i might have the same unevenness problem anyway. Also, I have a feeling ripping out that other tiles will be quite time consuming.
I think i would prefer to vinyl over the top of tiles it it is possible.
swanson is offline   Reply With Quote
Tags
options , sub floor repair , vinyl flooring
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Leveling a VERY uneven basement floor cbeingessner Building & Construction 1 09-04-2009 09:54 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
how to level an incredibly uneven cement basement? rbes Flooring 6 09-09-2008 04:32 PM
