Uneven Garage Slab-on-grade - Flooring - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 07:34 PM   #1
uneven garage slab-on-grade
Hi,
I am turning my old single garage into a leisure room.
The concrete slab-on-grade is broken in a few places and clearly up to 2 inches in height deviation between various parts of the 10' x 14' slab.
I would like to turn the garage into a small meeting room, and know how to deal with the roof, ceiling, and walls.
The overall height from current floor (largest even area) is 89 inches.
Any help on the floor would be great, including how to finish it knowing heat could be installed via electric heater, or is in-floor possible?
thanks
wwsteel is offline   Reply With Quote
Old 10-16-2010, 01:21 AM   #2
jlhaslip's Avatar
Rewards Points: 946
Jack hammer it out and pour a new slab.
In-slab heat could then be added.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-17-2010, 04:01 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are the walls built on separate footings or are they built directly on the slab?
XXX
Old 10-17-2010, 05:09 PM   #4
Registered User
Rewards Points: 5,212
Check with local B.D. as they may have requirements for this. May need a window for light and ventilation, stem concrete wall for siding replacing vehicle door clearance for spash, etc.:
Garage conversions
• Parking: To convert your garage to living space, you may need to show how you will provide a
required onsite parking space. Parking in your driveway alone may not meet this requirement.
• Setback: If you want to convert a detached garage to living space, the zoning code allows conversion of some existing garages within the side or rear setbacks with limits on size and height. Check with Planning and Zoning before conversion.
• Firewall: If the exterior wall is less than three feet to a property line, a fi re wall without openings will be required. http://www.portlandonline.com/shared...e.cfm?id=93019
This will give you a paper trail for your H.O. Insurance and code built so you don’t need to rip it out when selling.
Gary
need to fix the foundation on this slab garage cnn7 General DIY Discussions 3 04-20-2010 06:11 PM
Annie5 - framing over uneven concrete floor Annie5 Carpentry 9 11-22-2009 04:26 PM
uneven concrete slab in house underthegun Flooring 2 08-27-2009 03:04 PM
Floor Drain retrofit for Slab on Grade Douger_F Plumbing 3 04-02-2009 12:07 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
