Uneven Flooring... Help Please... - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 02:15 PM   #1
Uneven Flooring... help please...
Hi all,
My name is mike and I recently took down a wall seperating the kitchen and dinning room. The kitchen is part of a newer addition build years after the house was built. After the wall was removed, carpets and laminate floors torn off, , beam was installed, I realized the hardwood flooring is 1/2'' higher in the addition room then the rest of the house. The idea was to put hardwood floors throughout the now 1 large kitchen. I will be installing an island that would overlay both sides of the rooms . How would one recommend fixing this issue without having a rise or step-up, since the island wont allow this.
mslattery is offline   Reply With Quote
Old 01-12-2011, 08:47 PM   #2
anyone have any suggestions?
Old 01-12-2011, 09:42 PM   #3
DIY staff
Rewards Points: 7,174
This is where a picture would help-----One floor is going to have to be changed--But to what?
Need pictures.--Mike--
Old 01-12-2011, 09:47 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Screw 1/2" thick plywood to the sub \floor on the lower side.
That was easy...where's my button?
Andy.
AndyGump is offline   Reply With Quote
Old 01-12-2011, 09:54 PM   #5
DIY staff
Andy,That was fast--now go design the kitchen in the other post
--Mike--
AndyGump (01-13-2011)
Old 01-13-2011, 12:27 AM   #6
Yep Add the Plywood is correct . the only thing I would look out for is ,if the dishwasher will slide in and out . Or if you have to raise the cabinets where the dishwasher will go also .
tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
laminate flooring on uneven sub floor? ponch37300 Flooring 25 04-06-2013 10:29 PM
resilient flooring and uneven floors boxy_brown Flooring 1 03-06-2012 02:07 AM
Uneven Floor Edge for Laminate Flooring sgk Flooring 1 06-21-2010 06:23 PM
Uneven cement flooring, need to put something "soft" on top for mother in law..? andsoitgoes Flooring 13 05-31-2009 10:51 AM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
