-   -   Uneven Floor Edge for Laminate Flooring (http://www.diychatroom.com/f5/uneven-floor-edge-laminate-flooring-74281/)
sgk 06-21-2010 04:24 PM
Doing a little remodeling in an old house, and ripped up the carpet in the dining room to put down Laminate flooring. After I got it cleaned, I noticed that one of the sheets wasn't even with the others. It looks like one of the 4x8 pieces used for the flooring is off a little. The room is 11.5'x19.5' so there are two edges where it doesn't line up.
I assume that just the one section is 1/2" where the rest of it is 3/8". When I lay down the padding and laminate, is this going to make a difference?
If it will make a difference should I use shingles or tar paper to try to minimize the change?
Shamus 06-21-2010 07:23 PM
Originally Posted by sgk (Post 459425)
I assume that just the one section is 1/2" where the rest of it is 3/8". When I lay down the padding and laminate, is this going to make a difference? Yes
I'd pull up the 1/2" pc and replace with 3/8" to flatten the floor. Otherwise you'd need to raise the entire floor to the height of the 1/2".
Just my 2
