Uneven Concrete Basement Floor Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 03:04 PM   #1
Uneven concrete basement floor problem
Hi-
I am a homeowner with very little knowledge of sub-floor options for my new basement project. I want to install Pergo flooring ... but my concrete floor is very uneven. What is the best available option to level the concrete floor before laying the engineered wood flooring .. My basement is dry & my contractor is recommending 5.5 mm plywood underlayment glued directly on to the concrete floor .. will this address the uneven floor issue or will my laminate flooring laid over the plywood sub-floor still be uneven.
Novice_Minty is offline   Reply With Quote
Old 02-16-2013, 03:08 PM   #2
Rewards Points: 14,278
Might want to hold off on this one until a few of the full time flooring guy chime in.
I know I would never install plywood directly to any slab, and I know for a fact I would never glue it down. I also would never suggest any laminite be installed be low grade.
But ha that's just me, lets see what they say.
Old 02-16-2013, 03:20 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
I don't consider myself as an expert in laminate installations, but WOW, I'd be looking for an installer that isn't recommending that process. Ply on a slab and it's below grade too? Add to all that it's 5.5mm which may indicate luaun..strike 3.
So according to this "contractor", if you installed 5.5mm ply on your roof, it would make it flat? I don't think so.
BTW, Pergo is not engineered flooring.
The answer is easy, the solution not so. You need to make the floor flat using Portland cement based patching materials. Not always possible in basements if there's drains involved.
Jaz
Old 02-16-2013, 03:27 PM   #4
If I did this right that's only .216 which is even less then a 1/4". (.250)
Old 02-16-2013, 06:10 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
That's right Joe, .21654 actually. I don't care if it's 1/2" or even 3/4", it'll bend when fastened. But you shouldn't be using ply on concrete anyway. It's not gonna change anything.
Jaz
Old 02-16-2013, 06:13 PM   #6
I was agreeing with you Jazz.
May as well lay a veneer if it's going to be that thin.
Old 02-16-2013, 06:42 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
Might as well paint the concrete brown.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-17-2013, 09:12 AM   #8
Rewards Points: 240
yep. or stain it. some of those stains look AWESOME !
but putting down tile that looks like wood, thats it.
Fix'n it is offline   Reply With Quote
Old 02-18-2013, 11:21 PM   #9
The solution depends on two things (a) intended purpose of the room and (b) how much are you willing to spend.
Best solution is level (even flatness) through the room with self leveling concrete or diamond grind all the high spots so it is "flat". This should be done if the basement will be used regularly with heavy furniture.
Cheaper, worst option, is to use thick underlayment under the floating floor, however stress at the joints of the laminate where you walk or place heavy items will cause cracking and ruin the floor. If the low spot is a rarely walked on spot you may get away with it, I'm not saying do this.
Your call based on $ and intended purpose.
rebelranger is offline   Reply With Quote
Tags
flooring , plywood subfloor , sub-floor , uneven basement
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Demolishing Basement Concrete Slab... CarlsonRower Remodeling 21 03-21-2012 07:46 AM
Frame Concrete Half Wall in Basement VikingDinKC Remodeling 6 03-09-2012 08:31 AM
Condensation on concrete floor under basement fiberglass shower/tub insert bsande2 Building & Construction 2 01-22-2012 07:02 PM
Concrete Basement Beam jrepp44 Building & Construction 1 01-06-2010 01:39 PM
