Uneven Cement Flooring, Need To Put Something "soft" On Top For Mother In Law..? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 10:14 PM   #1
Uneven cement flooring, need to put something "soft" on top for mother in law..?
I'll try to explain this again, since my last post got wiped out because I forgot to log in...
our in-laws live in our basement. We have a full suite there. The kitchen in their area is the "center" of the foundation and, for some reason, it shifted and because it's on slab, it's created some waves in the concrete. no MAJOR drops, but some waves that make it impossible to put flat flooring down on top of it.
They have peel-and-stick tile on it now, and it's incredibly obvious where the sections are because the concrete is poking up through those areas. I know I'm not doing the best job explaning this, and I'll take some pictures tomorrow which might make it a bit clearer as well.
The kitchen is maybe 200sqft? I'm horrible at measurements, but it's far from huge. It extends out into a small maybe 2 feet walkway to the living room. The flooring that touches these areas is a laminate, and it sits above the slab.
Our goal is to find a way to level the floor (suggestions?? ) first.
Then, figure out what to put on top to soften it as much as possible.
Unfortunately carpet in the kitchen went the way of the 70's, or else we'd do that
What would be good that would be soft for a nice old lady's feet, but easy to lay?
Cost and ease are obvious an issue here. We'll probably have to do it on our own. My father in law has experience, somewhat extensive, with renovation projects but seeing as he's in his 70's and that I'm limited in my abilities due to previous injuries, I'd like some advice from people that do it all the time.
Any help would be greatly appreciated!
andsoitgoes is offline   Reply With Quote
Old 05-27-2009, 06:36 AM   #2
Leveling cement does an excellent job, and can be a thin as is needed to level things up. But you must build a dam around the floor and seal all cracks and crevices, or the compound will leak out. It is literally like water once mixed, and generally self leveling, but hardens quickly.
Old 05-27-2009, 07:01 AM   #3
the Musigician
DangerMouse's Avatar
get a hooker? -=chuckle=-
orrrrr....
cork.... warm, soft and easy to install.
DM
Old 05-27-2009, 08:20 AM   #4
call in someone who specializes in conc grinding then install any soft floor you wish such as cork,,, we'd do a moisture ck 1st prior to installing anything
yesitsconcrete is offline   Reply With Quote
Old 05-27-2009, 09:09 AM   #5
the Musigician
good point, yesitsconcrete.
i think i'd also explore the WHY it shifted aspect to find out if it'll continue after repair?
DM
Old 05-27-2009, 09:43 AM   #6
i suspect expansive soils but the 'wave' is interesting as hi flexural strength isn't usually a characteristic of residential conc in my experience, mouse
Old 05-27-2009, 02:47 PM   #7
Floorwizard's Avatar
Fiberglass backed Vinyl flooring.
Mannington Sobella
Armstrong Cusion step
ect....
Floorwizard is offline   Reply With Quote
Old 05-27-2009, 07:11 PM   #8
hard to argue with a SUPERmoderator would be nice to know how high the projections are, tho
Old 05-28-2009, 11:23 AM   #9
not very
Old 05-28-2009, 12:20 PM   #10
high or difficult to argue what's the ride of choice up there ? ? ?
Old 05-28-2009, 03:58 PM   #11
Harley's mostly.
for me it's a V-Star 650 custom
Old 05-30-2009, 11:07 PM   #12
I think the Mannington is what my brother in law used.
I would think Cork would be softer though, wouldn't it? Cost is obviously of importance, but if the cork flooring is significantly cheaper, I think that would be a better angle...
IS it softer? There's not a lot of places to find this stuff in western Canada, it seems.
Old 05-31-2009, 05:17 AM   #13
the Musigician
i'd think cork would be softer AND warmer. seems to me, living where you do, it'd be quite popular!
DM
Old 05-31-2009, 10:51 AM   #14
and click-lock is right up my alley
Although the plain tiles might be easier with the possible slight slope left after it's leveled?
laminate flooring on uneven sub floor? ponch37300 Flooring 25 04-06-2013 10:29 PM
good flooring over cement basement and near to a GFA furnace? idic5 Flooring 3 05-20-2009 11:38 AM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
how to level an incredibly uneven cement basement? rbes Flooring 6 09-09-2008 04:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
