Uneven Areas In Tile Backer - Flooring - DIY Chatroom Home Improvement Forum
Old 01-03-2008, 11:54 PM   #1
Rewards Points: 462
Uneven areas in tile backer
I installed the tile underlayment yesterday and next comes the tile. I just have one concern:
When working on my layout there are some areas where the tiles (12 X 12) rock slightly, maybe 1/16". Also, the 2 seams where I taped are slightly higher and the tiles rock on top of them as well. I knifed the areas as flat as I could when applying the thinset over the tape but it still created a slight high spot, again about 1/16".
Is a properly applied mortar bed, using a 1/4" X 3/8" notched trowel per manufacturer's instructions, going to take care of the slight imperfections in the floor or am I facing more prep work?
Richo is offline   Reply With Quote
Old 01-04-2008, 07:33 AM   #2
Rewards Points: 150
your mortar bed will take care of a 1/16" hieght difference.
If your a real freak (like me) you could always take a belt sander to it
mike costello is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
tile backer board yudamann Flooring 1 06-29-2006 07:53 PM
