Old 08-29-2011, 01:01 PM   #1
Underlayment for Vinyl FLooring
My kitchen subfloor is 1x boards over 2x8 joists and the rooms next to it are 3/4" hardwood. To make up the difference should I go with 1 layer 3/4" a-c underlayment ply wood or two layers 1/4 sureply over 1/2 exterior grade ply with lower quality face. I am concerned about flex in the floor and fasteners showing through. I could screw down the 1/2 and then staple the 1/4" over it. Or just staple down 3/4". I would prefer not to use adhesive on the subfloor as it would be difficult to pull up later. Right now there is particle board over the subfloor that is swelling in places has to go.
Which way should I go?
JimV is offline   Reply With Quote
Old 08-29-2011, 01:46 PM   #2
Pro Flooring Installer
rusty baker's Avatar
I would screw down the 1/2 and staple 1/4 over it. Then if you can't get the vnyl adhesive up later on, you would only need to change the 1/4".
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
underlayment for click and lock hardwood flooring fawnlion Flooring 2 12-06-2010 04:03 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 03:00 AM
Underlayment for Laminate Flooring nyseguy Flooring 2 04-12-2010 09:45 AM
installing underlayment for laminate flooring homeimprovement Flooring 2 10-01-2008 11:46 AM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 05:09 AM
