Underlayment Removal Around Toilet - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 09:27 PM   #1
Underlayment removal around toilet
My question is pretty simple, I'm in the process of renovating one of my bathrooms, I need to remove the underlayment from the floor but I am not sure if I need to remove the flange that the toilet was sitting on. The question is do I need to remove this flange or when I start to remove the underlayment is it going to have just been cut to accommodate the flange so I should just be able to pull the underlayment and the toilet flange will remain exactly where it is at currently.
Thanks!
donmigga83 is offline   Reply With Quote
Old 03-23-2011, 09:48 PM   #2
DIY staff
Rewards Points: 7,174
You won't know until you lift the toilet---Underlayment is most often cut around the flange.
If it is under the flange ,and in good shape,you can leave it---just cut around the flange with a chisel or Multi tool.
Post a picture if you have more questions when the toilet is removed.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Removal of underlayment under toe space eyeglass Flooring 10 08-26-2009 04:59 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
rusted toilet flange removal? Boughamer Plumbing 4 07-06-2008 06:44 PM
