-   -   Underlayment removal around toilet (http://www.diychatroom.com/f5/underlayment-removal-around-toilet-99366/)
donmigga83 03-23-2011 09:27 PM
My question is pretty simple, I'm in the process of renovating one of my bathrooms, I need to remove the underlayment from the floor but I am not sure if I need to remove the flange that the toilet was sitting on. The question is do I need to remove this flange or when I start to remove the underlayment is it going to have just been cut to accommodate the flange so I should just be able to pull the underlayment and the toilet flange will remain exactly where it is at currently.
Thanks!
oh'mike 03-23-2011 09:48 PM
You won't know until you lift the toilet---Underlayment is most often cut around the flange.
If it is under the flange ,and in good shape,you can leave it---just cut around the flange with a chisel or Multi tool.
Post a picture if you have more questions when the toilet is removed.
