Underlayment For Quickstep Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-01-2005, 10:05 AM   #1
Question
underlayment for quickstep laminate flooring
We have chosen quickstep for our laminate flooring, however, unsure which kind of underlayment to use. I do believe we must use a quickstep brand to get the full warranty. We are putting the laminate flooring on concrete floor in south Florida. How's the 2 in 1. Any suggestions?
Pturner is offline   Reply With Quote
Old 01-03-2005, 01:24 PM   #2
Floorwizard's Avatar
2 in 1 is exactly what you need.
Floorwizard is offline   Reply With Quote
Old 01-08-2005, 11:34 PM   #3
Contractor
Seal your slab first and follow up with 2 in 1.
I install lots of flooring in So. FL and sealing the slab is just as important as the vapor barrier. 2 layers of the 2 in 1 is close to some of the higher priced underlays. In FL, seal, seal, seal!
Teetorbilt is offline   Reply With Quote
Old 03-07-2005, 01:08 AM   #4
Use The 3n1 Its A Lot Better. Sound Moisture Pad
lowes#1fan is offline   Reply With Quote
Old 05-30-2005, 12:55 AM   #5
sell laminate flooring
Sorry. No unauthorized advertising is permitted on this site.
ritayu is offline   Reply With Quote
Old 05-30-2005, 04:09 AM   #6
Profeesional?
ha
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 03:39 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 12:05 PM
