Old 04-01-2005, 09:14 PM   #1
Underlayment for laminate
Is it necessary to put underlayment under laminate flooring? We plan to go over existing vinyl tile in dining area and plywood in the kitchen. Is underlayment more for soundproofing or does it help the laminate to lay better?
dm62 is offline   Reply With Quote
Old 04-01-2005, 10:14 PM   #2
Floorwizard's Avatar
it helps keep the warranty!
Since the beginning, lams have had underlayment.
Until they invent one that doesn't need it, I would use it.
It's cheap stuff anyway.
Floorwizard is offline   Reply With Quote
Old 04-02-2005, 08:59 AM   #3
Send a message via MSN to Benhamcarpetguy
I agree. No point in voiding your warrantee just to save a little time and $$$. The better the underlayment the more sound absortion you will enjoy.
Don
Benhamcarpetguy is offline   Reply With Quote
Old 04-02-2005, 11:56 AM   #4
pro flooring installer
Send a message via AIM to floorman Send a message via Yahoo to floorman
It will sound hollow anyway ,no need to enhance the echo from the laminate by not doing so.It will also help with the flatness of the floor and give it something to rest on
floorman is offline   Reply With Quote
Trafficmaster Allure - Underlayment? HuskySkull Flooring 41 09-23-2012 03:28 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 06:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
15 lb or 30 lb underlayment? Hossman Roofing 6 09-13-2005 11:47 PM
