Underlayment For Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 11-02-2008, 01:00 AM   #1
wilderstyle
Question
Underlayment for laminate
I am renovating a house to sell. Do I have to pull up the pad from the previous flooring if it is still good? I already purchased the plastic 2 way stuff that goes with my laminate flooring. I could take it back and save some money. Opinions please!
wilderstyle is offline   Reply With Quote
Old 11-02-2008, 03:45 PM   #2
Home Imp./Remodeler
Is the laminate going on a concrete or plywood subfloor? If concrete, make sure your underlayment has a vapor barrier or put one down before the underlayment.
If the existing pad you're asking about was for a carpet, definitely pull it up first. There's far too much "give" in a carpet pad for laminate. The planks will move each time they're walked on and eventually lead to failure of the T&G locking system.
Dan V. is offline   Reply With Quote
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
Additional underlayment needed ?? nathan.tran Flooring 1 07-25-2008 03:21 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 04:17 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
