Underlayment For Laminate - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 07:24 PM   #16
Where is the springy area? Is it along a wall, in the middle, etc......
I had the same situation when I installed some Laminate recently in my own house And the biggest spring was in a couple corners. Normally I would want to do it right but this room does not see too much use so I left it be. If you step directly in the corner it drops a good amount but it is not often that happens.
If it is an area of traffic I would do it right and level it out.
Elkypro is offline   Reply With Quote
Old 12-31-2012, 07:39 PM   #17
Rewards Points: 1,050
It's not in a corner, more in the center of the room (not exactly the center though...)
It's the family room, and we want to make it a TV room....I would say traffic will not be too high
Some pieces of furniture may put "pressure" on it, then it won't move anymore....Not sure
french_guy is offline   Reply With Quote
Old 01-01-2013, 12:40 PM   #18
Well, I think I will remove the laminate already installed and I will use some self-leveling mix to patch the lowest areas....1 bag should be enough and I will prepare some mix by smaller portions (not the whole bag in 1 shot)
It sucks, but I don't like the way it is right now!!!
By the way, where can I find a long (6 or 7 feet) aluminum rule to apply those patches? I didn't find any at HD.....
Old 01-03-2013, 01:37 AM   #19
Rewards Points: 558
try the art store... Also did you look in the drywall section at HD?
epson is offline   Reply With Quote
Old 01-03-2013, 05:46 AM   #20
I think I looked everywhere at HD: lumber, building material, drywall, paint, hardware...............nothing
I just bought an aluminum angle bar (8' - 1,5" x 1,5" and 1/8" thick)
But it's overprice I think (~$40 with tax)
What do you mean by art store?
Old 01-03-2013, 02:39 PM   #21
Let’s say I want to make a wood sub-floor based on sleepers + OSB boards
Sleepers being attached to the slab with Tapcon screws, and OSB glued and screws onto the sleepers
Sleepers every 2 feet with some foam in between….
I was thinking to use 1” x 4” sleepers (2 x 4 will be too high)
1) Is it OK to go with 1 x 4?
2) Should I use pressure-treated or regular white pine boards?
3) Do I need the grooved and tongued OSB 4 x 8, or can I go with squared edge as long as there are sleepers under each edge?
4) What shouldbe the minimum thickness of the OSB?
Old 01-03-2013, 03:49 PM   #22
Rewards Points: 558
You were looking for a long ruler and I suggested you look for one there.
Old 01-03-2013, 03:54 PM   #23
Rewards Points: 558
Lets say I want to make a wood sub-floor based on sleepers + OSB boards
Sleepers every 2 feet with some foam in between.
I was thinking to use 1 x 4 sleepers (2 x 4 will be too high)
You can read up on this: http://homerenovations.about.com/od/...ntSubfloor.htm
Old 01-03-2013, 03:55 PM   #24
Understood......but you mean stores like JoAnn?
Old 01-03-2013, 04:00 PM   #25
Originally Posted by epson View Post
Yeah...but they don't say anythiong about 1" x 4", only the standard 2" x 4"
Does that mean 1" x 4" is not feasible at all?
Old 01-03-2013, 04:02 PM   #26
Rewards Points: 558
Im from Canada; I dont know what JoAnn is? If its a good art store they should carry large rulers. You should have a Michaels, can try them. Im just thinking out loud as I have seen them around.
Old 01-03-2013, 04:11 PM   #27
Rewards Points: 558
read this link: http://www.buildingscience.com/docum...ms?full_view=1 Above pick was from link.
Old 01-03-2013, 05:54 PM   #28
My idea was to have the moisture barrier (6 mil film), anchor the sleepers (1" x 4") with the foam in between, resting on the moisture barrier, and on top of it OSB or Plywood
Now, do I need pressure heated sleepers or not?
Old 01-03-2013, 06:01 PM   #29
Rewards Points: 558
yes i would use them...
Old 01-03-2013, 06:06 PM   #30
3 more questions:
1) Do I need to leave a gap (1/4") between the walls and the plywood?
2) Do I need to leave a gap between each plywood board (knowing they will be glued and screwed on the sleepers)
3) Is groove/tongue boards mandatory or not?
1/2" sublfoor...what underlayment for hardwood? Jrhenry24 Flooring 10 10-04-2012 07:57 PM
concrete tile roof underlayment recommendations?? bobinphx Roofing/Siding 9 08-14-2012 10:20 PM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Underlayment question-- "extending" existing underlayment fastener and type cbrc5eric Flooring 9 06-01-2011 04:03 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
