Underlayment For Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 05:41 PM   #1
underlayment for laminate
What is THE best underlayment to use for Armstrong nature's gallery laminate on a concrete slab for moisture c ontrol, warmth and noise reduction?
capt is offline   Reply With Quote
Old 02-06-2012, 07:06 PM   #2
Rewards Points: 77
What does Armstrong recommend? You need to comply with their specs or they won't stand behind their product.
MNsawyergp is offline   Reply With Quote
Old 02-06-2012, 07:10 PM   #3
Rewards Points: 13,994
Laminites not a great choise for a below grade install. Very prone to water damage.
Concider engineered wood instead. it's real wood, can be refinished, far more stable, does not look like plastic like laimite does.
Old 02-07-2012, 07:39 AM   #4
Willing to listen
Rewards Points: 223
I've had good luck with my basement laminate installed over top of QuietWalk pad mfg by MP global.
Since there are so many variables from floor to floor and location to location a moisture test might be a good starting place before you go forward.
Done That is offline   Reply With Quote
Old 02-07-2012, 12:41 PM   #5
"Floor"ist
OtherFloorGuy's Avatar
Not familiar with the product, what is the backing made of? Fiberglass, paper, etc?
This will affect what kind of spread you use.
Above comment was right, manufacture will only support spec install.
OtherFloorGuy is offline   Reply With Quote
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 02:38 PM
Underlayment question-- "extending" existing underlayment fastener and type cbrc5eric Flooring 9 06-01-2011 04:03 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 02:00 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
