Underlayment For Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 05:26 PM   #1
Underlayment for hardwood floors
Hi,
I'm putting my pricing together for my hardwood floors, and I wonder if anyone has a recommendation for the underlayment. I see that they have paper and something at lumber liquidators called insulayment. Recommendations and reasonings?
Thanks in advance!
gtono is offline   Reply With Quote
Old 05-29-2011, 05:49 PM   #2
and I forgot to mention, it's a solid 3/4" x 3 1/4" prefinished stained maple.
Old 05-29-2011, 05:51 PM   #3
DIY staff
Rewards Points: 7,174
Most hardwood floor installers use rosin paper or 15# felt paper.
Felt paper is typically used on a floor with a possible moist area below--such as a basement or crawl space---
---Mike---
Old 05-29-2011, 06:00 PM   #4
Is felt only used for moist areas?
So, between the felt and the rosin paper, is felt only used for moist areas. I live on Conifer Mountain in Colorado, so air is very dry. Installation will be above ground, above walk-out basement.
Old 05-29-2011, 06:40 PM   #5
DIY staff
Some installer only use the felt paper--so you can err for caution and use that if you have any doubts.
That's all I used to use long ago----Mike----
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 02:00 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 03:58 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
