Underlayment For Floating Engineered Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 10:01 PM   #1
Rewards Points: 137
Underlayment for floating engineered floor
I am about to install a floating engineered wood floor. It will be in a second story bedroom with no moisture concerns. It will be installed over a very level and even OSB subfloor. Do I need an underlayment? And if so what? I have been researching this and have seen everything form no underlayment to 1/4 inch cork and everything in between.
Troy32 is offline   Reply With Quote
Old 07-12-2013, 07:48 AM   #2
Remodeling Contractor
No you don't NEED an underlayment. You can simply use roofing felt like under nail down hardwood just to have a break between the OSB and underside of the engineered wood. Sometimes a felt type pad helps to quiet the wood. I've done both with good results
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
Old 07-12-2013, 07:56 AM   #3
Rewards Points: 14,306
A cork underlayment will give you the most bang for the buck when it comes to sound transference.
Old 07-12-2013, 08:42 AM   #4
If cork is not available where you are. CERAZORB - http://www.cerazorb.com/index.htm
is also a product designed to absorb sound transfer. You said your installing on a second floor.
Phil,
Old 07-12-2013, 11:27 AM   #5
Rewards Points: 137
Always seem to get great feedback here. Thanks gentleman
Old 07-12-2013, 12:20 PM   #6
Ain't no gentlemen here. Lol
Phil,
Help picking engineered hardwood floor Novice_DIY Flooring 5 07-12-2012 09:54 AM
Need a lot of underlayment to straighten out a floor. Need help! rafalc Flooring 6 02-06-2012 06:56 PM
floating engineered floor perpendicular to stair nosing Rad111 Carpentry 5 02-27-2011 02:48 PM
Help in solving an engineered floor problem simplemind Flooring 6 01-24-2011 03:45 PM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 03:17 PM
