Old 11-03-2009, 10:48 PM   #1
Underlayment
I need to install underlayment. It will be 1/4 thick over the subfloor to provide a smooth surface. One room will be vinyl "sticky" tiles while the other will be carpet.
The "big box" store I go to (Menards) has several 1/4 types. Which would be the best?
The plywood they have marked as underlayment and has x's all over it to mark where to fasten it, is $20 a sheet and it says it's used specifically for underlayment.
Then there is maple veneer plywood for $15 a sheet. It's sanded smooth on the maple side. I'm not sure why it's cheaper though. I would think it would be more. Would that work as a good underlayment?
Lastly, you have Luan (if I spelled it right). I've read a bunch of websites that say it's good to use, and others say to stay away from it. I think that’s $10 a sheet.
All sheets are 4x8.
Also, do you recommend stapling, nailing, or screwing the underlayment down?
Thanks for your help!
Dave
dcf1999 is offline   Reply With Quote
Old 11-04-2009, 06:55 AM   #2
Doer of Many Things
poppameth's Avatar
Underlayment
Luan is okay but generally the bottom of the barrel. For what you are doing though, it's probably fine. I wouldn't expect most self stick tiles to be a long term investment anyway. The expensive stuff if usually a 5 layer birch and carries a warranty. It's all we use.
Poppa Meth Entertainment
poppameth is offline   Reply With Quote
Old 11-04-2009, 10:39 AM   #3
Underlayment
  • Luan
  • Staples (faster to install and MUCH easier to remove later)
  • Only use in the room(s) to recieve the vinyl tiles
  • Screw your sub-floor to the joists to eliminate current and prevent future squeaks
MI-Roger is offline   Reply With Quote
Old 11-04-2009, 02:24 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Underlayment
Underlayment should be stapled. A 4"x4" pattern in the fields and every 2" on the seams. Luan is used as underlayment but certainly is not the best thing to use. Luan ususally has voids which can give underfoot.
Armstrong Certified
Retired Installer
ANY PRODUCTS ADVERITISED IN MY POSTS ARE NOT ENDORSED BY ME!
Old 11-04-2009, 11:26 PM   #5
Underlayment
Thanks for all your help. I will use staples and have found Plywood underlayment for about $11 a sheet that I will be using.
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 04:17 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
