Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2008, 08:10 PM   #1
Underlayment
New here. Thanks for viewing.
I'm installing underlayment for a vinyl, bathroom floor. I'm using ring-shank nails as recommended by the local lumber yard to attach the underlayment. (2) questions:
1) How far apart should I space the nails?
2) Do I have to use floor leveler to level the nail heads? I've read where you just need to nail them flush to the underlayment and only use leveler on the seams of the underlayment, not on any of the nails.
Again, thanks!
dhar2112 is offline   Reply With Quote
Old 04-14-2008, 08:59 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
In this area only staples are used. One quarter inch crown staples that "set" themselves. They are placed 4 inches apart in all directions. I doubt you'll ever be able to set all the nail heads so they won't telegraph and I'm equally sure the use of floor leveller will only intensify the problem. In addition...ring shanks really wouldn't be necessary I wouldn't think.
Maybe others do it differently.
Old 04-14-2008, 09:11 PM   #3
Thanks. I'll try to track down an air-stapler.
Old 04-15-2008, 12:38 AM   #4
Boz
Gus
Boz's Avatar
Nails....no, no, no. 1/4" crown with 7/8" legs every 4 inches, every 2" on the seams. Lightly but your joints and DON"T use any filler on the seams. Sand the seams till they are flush with a belt sander.
Boz is offline   Reply With Quote
Is Cork underlayment the best for a floating engineered floor project? lgkinney Flooring 2 04-05-2008 03:17 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 05:54 PM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 10:15 AM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
