Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2006, 11:51 AM   #1
underlayment
I am looking for a product that I believe is called 'Structure Floor'. It comes either cement board or osb. It has a coating on the bottom that forms circles. They form channels so that any moisture that gets underneath will not soak into the board. Any help would be appreciated.
JimD is offline   Reply With Quote
Old 01-23-2006, 03:00 PM   #2
Rewards Points: 77
Your not entirely clear on what your looking for or what the name of the product is, so let me ask a question.
Is this product intended use as a substrate going over a concrete slab on or below grade, such as in a basement?
If that is so, I have seen such a product at Menards Lumber. They come in 2x2 or 3x3 panels that interlock they are ABS or some other plastic with some raised gridwork and had OSB as a finish substrate suitable for carpet installation. Their purpose to eleminate the need for sleepers I guess. I would not use either in any basement that was prone to seepage, or any but the most remote possibility of water. I know we like to keep out toes warm but that's why they make slippers.
John
Zero Punch is offline   Reply With Quote
Old 01-23-2006, 03:09 PM   #3
It is meant to be used in a basement much the same way as sleepers. Thanks for the info.
Old 01-24-2006, 07:18 AM   #4
Found it
I have found two differant types of panels. DriCore and SubFlor. Thanks
Old 01-24-2006, 01:42 PM   #5
Remodeler
MinConst's Avatar
Jim,
DRIcore is the product you want. I've used it and it is a great subfloor. It is a floating floor.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 01-24-2006, 09:20 PM   #6
Home Improvement Guy
ron schenker's Avatar
I've used Dricore also in basements. It's tongue and groove and moisture can flow under it without damaging the flooring. It's important to have a floor drain underneath somewhere. Up here in Toronto it's about 6 bucks for a 2'x2' panel.
ron schenker is offline   Reply With Quote
Old 02-04-2006, 12:34 PM   #7
Dricore evaporative process
I keep seeing on all the dricore literature that the raised bumps on the panels allow air to circulate and allow accumulated moisture to evaporate. My question is; Where does all this moisture evaporate to? The top is sealed by the poly coating and the edges are effectivly sealed by interior stud walls, molding, finished edges, etc.. I would think the moisture is still trapped with this system. Thanks in advance for any insight.
skipolonius is offline   Reply With Quote
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 04:04 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Underlayment for laminate dm62 Flooring 3 04-02-2005 10:56 AM
