Underlay For Heated Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 10:29 AM   #1
Underlay for heated flooring
My in-laws own a construction business (mostly excavation, and heavy machinery) and in their shop office they have just bare concrete for flooring. The dust that gets in there is unbearable for my mother in law and she wants to put laminate down so its easier to clean.
What she is worried about is the heated from the in-floor heating not making its way through the underlay and laminate into the room. She was wondering about using something other than traditional underlay to keep the noise down but allow the heat to get into the room.
She had mentioned an underlay that is something like paper, I thought something like roofing felt might work as well.
Can anyone give me any ideas?
Thanks.
AA
ahrens is offline   Reply With Quote
Old 01-07-2012, 10:52 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ahrens View Post
...they have just bare concrete for flooring... wants to put (edit: something) down so its easier to clean. What she is worried about is the... in-floor heating not making its way through (edit: something) into the room.
Vinyl Composition Tile: Open This Link
Durable, inexpensive, easy to install... and easy to clean.
hth
Old 01-07-2012, 11:26 AM   #3
Rewards Points: 13,270
The heat would still work fine. There's even underfloor retro fit under flooring heating that's installed in the floor joist bays for under hardwood flooring.
I would use 6 mil plastic not tar paper. Tar paper would make the floor stick as it tryed to expand and contract.
Old 01-07-2012, 11:27 AM   #4
Sorry i shouldve mentioned that she already bought some laminate flooring, just wondering about an underlay.
Old 01-07-2012, 11:43 AM   #5
MarginallyQualified
...should've mentioned that she already bought some laminate flooring...
Return it. Seriously... the veneer surface of laminate isn't going to hold up to the abusive environment that you described in post #1. This application "construction business (mostly excavation, and heavy machinery)" implies both blown in dust and such but also what gets tracked in on boots and clothing.
hth
Laminate flooring underlay... BCSapper Flooring 5 11-11-2011 12:27 AM
Underlay for 3/4 Cumaru hardwood flooring Paul8434 Flooring 6 10-22-2011 01:05 PM
Allure flooring foam underlay? phess44 Flooring 0 05-24-2011 03:41 PM
Underlay for Laminate Flooring Zee 32 Flooring 9 12-13-2009 02:20 PM
Acoustic Underlay for Wood Lamninate Flooring darrenbooy Flooring 7 11-08-2006 01:48 PM
