Ugly Cold Floor In Basement Washroom Makes Wife Grumpy - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 04:33 PM   #1
Cold Floor in Basement Washroom = DriCore OK for Porcelain Tile SubFloor?
My ugly cold basement washroom floor is making my wife grumpy so my idea is to put down some snazzy italian porcelain tiles to cheer her up.
I'd like to use a DRIcore subfloor to separate the tile from the pad and thus warm things up a bit. my concern is that i've heard that porcelain tile requires a very firm base or they will crack. do you think the DRIcore is firm enough that I can apply the tile directly to it?
if not, my other idea is to stick a layer of DITRA between the DRIcore and porcelain tile to give the tile some separation from the DRIcore. the DITRA adds a couple of bucks per square foot but i'll use it if needed. thoughts?
I've been laid off and now have a bit of time to work on the house. this will be the 1st project to tackle.
Thanks in advance.
http://www.dricore.com/
http://www.schluter.com/6_1_ditra.aspx
Last edited by slydevil; 02-11-2010 at 07:59 AM. Reason: made the question more specific
slydevil is offline   Reply With Quote
Old 02-10-2010, 05:02 PM   #2
Rewards Points: 4,800
you'll score more if you also include an electric heat grid warm tootsies seem to warm more than the cockles of their romantic thoughts if you know what i'm saying to you
Old 02-10-2010, 05:07 PM   #3
i'm sure you're right about that! her cockles definitely need some warming if you know what i'm saying.
Old 02-10-2010, 05:12 PM   #4
Newbie Bill
Rewards Points: 522
The electric heat grid was my thoughts exactly. I'm not touching the romantic stuff.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-10-2010, 05:30 PM   #5
the washroom's small (9x9) so it might be worth it. are they expensive? approx. cost per sq.ft?
Old 02-10-2010, 06:39 PM   #6
Newbie Bill
Rewards Points: 522
Not sure.
Try this site.
http://www.warmup.com/
Bill
Old 02-11-2010, 08:04 AM   #7
Checked HD today, a 20" x 26' electric heat grid goes for about $275 not including themostat. i might get one for the upstairs washroom that is used more often but maybe too pricey for the amount of joy i'll get with this room.
Old 02-11-2010, 08:10 AM   #8
I looked at the matts too & passed
Instead I bought the wire
For the same $$ as the matt I was able to do the bathroom & thehallway outside the bathroom...plus a little down the long hallway
I walk around barefoot or in socks a lot
The warm 70 degree tiles really feel a lot better on the feet
Plus our bathroom does not have a radiator
I will be installing another setup on our 2nd floor
And alos in the new sunroom
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
untouched basement + nagging wife = no good.......... help!? NeedSeriousHelp Carpentry 2 07-01-2009 08:22 AM
How to fix cold floor - air intrusion from basement Leah Frances Building & Construction 4 01-13-2009 09:26 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 08:42 AM
