Tyroc - Flooring - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 07:15 AM   #1
Tyroc
I was wondering if anyone has used this product and have any reviews with it? Was thinking of using it for my basement bath reno then tile on top
http://www.tyrocinc.com/
zoolou is offline   Reply With Quote
Old 04-28-2011, 11:29 AM   #2
Not sure about tiling on it..... But I think this product is the best combination of materials to date.
seamus Mc is offline   Reply With Quote
Old 04-28-2011, 08:09 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
From a tileguys standpoint:
The video says the product can be used under ceramic tile. But, based on the demonstration in the video I would challenge that wisdom.
I also would doubt it would conform to an uneven concrete surface without some serious lippage of the sheet/board edges. Under tile that condition would be unacceptable. A moving substrate guarantees broken tiles and loose crumbling grouts.
Technically nothing is required for an underlayment when installing tile to concrete.
Looks like a great product for installing under laminate flooring or carpet.
XXX
Old 04-29-2011, 07:50 AM   #4
Once I get this paint off and get the floor level............I think I am going with the Tyroc then laminate.
Old 04-29-2011, 04:12 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why do you need the Tyroc with laminate?
XXX
Old 04-30-2011, 10:49 AM   #6
You only need the thin pad under the laminate that they sell with it. How much is the tyroc a sheet?
You dont need to get the paint off the floor if you are putting laminate down. my uncles neighbor had laminate put down in his living room and they left the carpet padding under it . its cheap laminate so it shouldnt be long til it cracking along the joints. the guy also lined up all the seams. (|:>).
Old 05-02-2011, 08:55 AM   #7
It's a basement. I want added protection in case of any small amount of water getting in.
Old 05-02-2011, 08:56 AM   #8
Gotta get the paint off so the leveling primer will bond properly.
