Type Of Screws For Securing Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 08:49 AM   #1
Rewards Points: 91
type of screws for securing subfloor?
What type of screws should I use for securing a subfloor? I've read anything from ring-shank nails to just regular wood screws.
The floor was constructed by first sistering new joists to the old ones, nailing and gluing 1x4 stock across the joists about 8-10" apart, then finally nailing and gluing 3/4" plywood on top. Is it necessary to screw through the 1x4s, or can I go directly through the joists?
debiasio is offline   Reply With Quote
Old 03-06-2011, 10:00 AM   #2
woodman58's Avatar
I would suggest using a premium wood screw for interior use 2 & 1/2 inches in length (course thread). You don't need to screw into the joists unless you just want to. The 1x's are already secured. I would suggest that you use liquid nail between the 1x4's and the ply.
woodman58 is offline   Reply With Quote
Old 03-06-2011, 10:38 AM   #3
Rewards Points: 200
Actually you don't want to screw into the joists .
Is the 3/4" plywood already glued and screwed to the substrate ?
PL400 is a much better adhesive then Liquid nail .
You can get it in large tubes at HD for around $6.00 a tube .
Check the dates on them , they tend to gas up if they been laying around for awhile .
Floor Doc is offline   Reply With Quote
Old 03-06-2011, 10:49 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I use GRK screws
tcleve4911 is offline   Reply With Quote
Old 03-06-2011, 12:27 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
There are many good screws you can use to install plywood to the subfloor. Add deck screws to the list. Just do not use drywall screws, as many do cuz they're cheap.
The subfloor should be glued and fastened to the joists. The underlayment, is NOT glued to the subfloor AND is fastened ONLY to the subfloor. Glueing the underlayment to the subfloor can actually create more bounch since it can create voids between the two surfaces.
Jaz
Old 03-06-2011, 08:32 PM   #6
Rewards Points: 91
It's glued to the 1x4s. I used PL Premium for the adhesive. Seems pretty solid.
Thanks for all of the suggestions. I have a good idea what to use now.
Old 03-06-2011, 08:44 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 290
This is the step that is not recommended. Next time fasten only, no glue between subfloor and underlayment.
Jaz
Old 03-07-2011, 06:09 AM   #8
Rewards Points: 91
Jaz
OK. I'll keep that in mind. Hopefully the once I screw down the plywood, it will be solid for a long time.
Subfloor in a Flood Zone lukew Flooring 8 02-18-2011 08:43 AM
Would you replace this subfloor? winterminute Flooring 2 11-30-2010 11:48 AM
Considering replacing playwood subfloor, many questions. gante Flooring 3 04-13-2010 12:39 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 01:26 AM
