Type Of Carpet Padding For Concrete Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-21-2014, 01:30 AM   #1
Type of Carpet Padding for concrete floor
We are currently considering 2 types of foam pad; a densified urethane and a Rebond. We've visited multiple stores and keep getting conflicting opinions about them. Some say that urethane's retain water, are noisy, and become compressed over time. Others list advantages as mold resistance, higher R values, and its more cushoney. What would you use on concrete floors
I'm not too woried about the basement has been "dry" for the last 3 years (we live on a large sandy mountain). I do not want to add a subfloor and would like to lay the pad on the concrete.
ppeetteerr is offline   Reply With Quote
Old 03-21-2014, 10:18 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Urethane pad has never been a great option. Rebond will last longer and will not compress like urethane. Rebond is normally cheaper too. Check and see what density and thickness pad, the carpet is supposed to have. It can make a lot of difference on carpet wear. Pad is available in thicknesses from 1/4" to 9/16" and densities from 4 lb. to 10 lb. Berbers normally need a thinner, denser pad than plush types.
Either type will work on concrete. If you do get moisture, in my experience, the rebond is less likely to have mold growth because water vapor can escape through it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following User Says Thank You to rusty baker For This Useful Post:
gma2rjc (03-21-2014)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Is there asbestos in horse hair floor padding? MustangEmily Flooring 0 02-13-2012 07:56 PM
Carpet to concrete floor transition papageek Flooring 1 12-13-2011 08:46 PM
Carpet + padding vs laminate (12mm) + padding (3mm) ml2010 Flooring 0 05-20-2011 09:59 PM
Remove bedroom carpet & paint the floor?? munsonfamily Flooring 2 07-20-2009 04:03 PM
