Two Days Redoing Laminate In Hall. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 10:45 PM   #1
Two days redoing laminate in hall.
Two days. Pretty much done. A little trim work to do.
Laid down a sound mat to muffle the cats, dogs and people walking in the hall. Turned the laminate boards so they matched the rest of the house instead of being totally opposite.
When I pulled up the old ones I found cat litter, hair under the wall trim along the boards and under them in some placesand dried sticky pee on two boards leading me to believe the person that put them down originally did not bother cleaning up before so, however, giving some shadow of doubt I am wondering if I could use a latex-type caulk along the boards under the trim to keep stuff from getting down in there?
I assume the latex would have enough give for expansion.
I have about 1/2" plus around all edges of the laminate except where it butts against the laminate from the hall to the living room and one peice in the middle of a doorway where my angled cut was off and I had to saw out the point of the board with my multitool. Anything I need to know or keep an eye on there?
Other than that it looks pretty good. A couple of boards simply have smooth ends butting and I used a sideboard with the 'lip' on each side to hold them in lace.
Satanta is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
