Tumbled Marble On Bathroom Wall - Flooring - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 03:01 PM   #1
Question
tumbled marble on bathroom wall
I am planning to set tumbled marble mosaic tiles (2 x 3) on bathroom walls Not in the wet zone. I have fastening densshield to the bwall studs and have discovered some dips and bows. What can I use to level the densshield? Will duoflex 90 mastic work? I am planning on using this to set the marble. Is mastic the right adhesive to use on densshield?
thegoatlover is offline   Reply With Quote
Old 09-15-2008, 03:34 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi,
You should correct the bows before you install the wallboard, not after. Is it done already?
The directions for your mastic claims to be OK for marble tiles installed on walls. I highly recommend you not using it though. You should be using a good quality white thin set mortar. These come ONLY in a bag, in powder form. As for does your mastic bond to Dens? Only the manufacturer can answer that, what did they say? Again though, use thinset. It's much better and much cheaper too.
Jaz
JazMan is online now   Reply With Quote
Old 09-16-2008, 12:09 PM   #3
Tags
tile adhesives
marble tile in bathroom floor Arianeg Flooring 1 03-18-2008 03:07 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 03:16 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 07:26 AM
