Tub/floor Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 03-31-2007, 07:05 PM   #1
tub/floor transition
I'm nearly finished installing ceramic tile in my master bathroom. I left a small expansion space between the new tile and the vertical side of the tub and I need to cover it up. In my other bathroom there is an L shaped metal strip that fits in the corner formed by the floor and tub. I've been to the Lowes and Home Depot neither has this item. What is this thing called and where can I get it?
diyron is offline   Reply With Quote
Old 03-31-2007, 09:20 PM   #2
Rewards Points: 77
Why not use colored caulk that matches your grout? It should be available where you purchased your tile and grout.
Zero Punch is offline   Reply With Quote
Old 04-01-2007, 11:42 PM   #3
zel
Rewards Points: 150
Send a message via AIM to zel
My Mom & Dad have that same strip on the back of their counter top, where it meets the verticle piece. Their kitchen was redone back in the mid 80's so I dont know where that stuff came from or where to get it, but maybe try a place that does counter tops? Maybe a supply company?
zel is offline   Reply With Quote
Old 04-02-2007, 11:35 AM   #4
HD selling those plastic strips for this purpose... it is good and easy to use for straight line... if you need to turn corner though, it will be harder to use...
KUIPORNG is offline   Reply With Quote
Old 04-02-2007, 04:09 PM   #5
zel
Rewards Points: 150
I seen a small bundle of samples of different "transition" edge pieces for tile at the end of the tile tool isle. I almost walked right by it, but they had a bunch to choose from, presumably special order.
Old 04-05-2007, 11:42 PM   #6
Floorwizard's Avatar
Tub strip can be commonly purchased at flooring stores.
Floorwizard is offline   Reply With Quote
