Old 11-16-2008, 11:12 AM   #1
True center?
How do you find true center of bathroom floor to lay tile? The floor is different widths and lengths.
Divinepoodles is offline   Reply With Quote
Old 11-16-2008, 12:02 PM   #2
Eibwen
True center?
If you have an odd sized room you'll want to find the center of your focal point which may not be the exact center of the room.
I.E. walking into the bathroom you want the largest longest area that you see of the floor to be your focal point. Offsets for toilets, vanities extra will follow.
Set your focal point center line from the wall and dry lay some tiles to see how things will look. Shift your center line as needed to get the look you want and minimize cutting or odd sized tiles.
Spend as much time as needed on your dry layout before actually setting the tiles. Its the key to getting the look you want.
Sammy is offline   Reply With Quote
Old 11-16-2008, 12:21 PM   #3
True center?
Thanks!
Old 11-16-2008, 12:23 PM   #4
Eibwen
True center?
Your welcome!
Good luck!
Post some pic's when your done.
Old 11-16-2008, 12:42 PM   #5
True center?
Your welcome!
Good luck!
OK, will do.
Old 11-18-2008, 01:04 PM   #6
Drywall contractor
True center?
Not the tile expert here, but have done a lot of acoustical ceilings. The layout is similar, and Sammy gives good advice. I try to get the "borders" as even as possible. In your situation, you might "hide" a narrow row of tiles under the toe kick of the cabinet (if using one), behind the commode area, etc. With several offsets, make the "odd" border in the smallest area possible.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-18-2008, 02:24 PM   #7
bradnailer's Avatar
True center?
If the room edge farthest from the entry way is slightly hidden, like with fixtures or cabinets, you can start with a full tile at the entry way. Don't worry about being totally balanced. As was said, when you look at the room at the most visible point, the tile should appear balanced.
bradnailer is offline   Reply With Quote
Tags
bathroom, center, floor, measure, tile
Center bearing wall ??? Clutchcargo Building & Construction 3 02-24-2008 08:00 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Cut in Center Beam Ryno10550 Building & Construction 27 12-26-2007 03:20 PM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 02:26 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
