Trouble With Carpet Seaming - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 12:37 AM   #1
Rewards Points: 462
Trouble with carpet seaming
Hi guys,
I am in the process of installing carpet in the basement. I am using a carpet that has an attached pad, yeah not the highest quality stuff but it will do the trick.
When it comes to cutting a seam, laying one piece on top of the other and cutting them both together is nearly impossible because the thickness of the 2 pieces is about 1.25 inches.
Also, this stuff cuts really sloppy when you cut it from the top down. I am having better luck flipping it over and cutting it from underneath. Still when it comes to seaming the stuff, I'm not getting the best results because I have to cut the 2 seams separately and then join them.
The 2 doorway seams I have done so far turned out OK but you can still see the line no matter how much you try to hide it, and I do have the joining pieces turned the same way so the knap is consistent.
Can anyone offer any suggestions? I have one 8 foot seam in the middle of a walkway that I would really like to hide and I am holding off on that one hoping for a better way. Thanks.
Richo is offline   Reply With Quote
Old 06-20-2009, 10:08 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Straight-edge both pieces from the back side. Seams usually show on that carpet because the backing isn't a consistent thickness throughout. Nothing you can do about that.
rusty baker is online now   Reply With Quote
Old 06-20-2009, 06:06 PM   #3
Rewards Points: 462
Yes, that's the way I did the second seam. It turned out better than the first so I guess that's as good as it's going to get given the nature of the carpet.
Thanks for the information.
seaming berber carpet greywolf6 Flooring 2 08-02-2008 03:01 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
