Trivertine All Thruout The House... Or Too Much? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 10:43 PM   #1
Rewards Points: 150
Trivertine all thruout the house... or too much?
wanted to install new flooring in my house. It is a small place about 1000sqft total. I thought about trivertine 24x24 (since designers say that large tiles make small places look bigger). I was wondering if I should install the same type of floor all over the house (rooms, restroom, kitchen and living room) or will it be too much. I did not want to have carpet in bedrooms, then a different tile style in restroom and the rest trivertine 24x24 since it would probably make the space look in pieces and not allow a flow. I really need sugestions, please what do you think?.
gante is offline   Reply With Quote
Old 01-25-2008, 01:14 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
The first thing to consider when installing a natural stone tile is the strength of the subfloor system. Many forget this. Very few homes are built to meet the deflection standards required for these tiles. Usually if natural stone is to be used, the builder must make necessary changes in the subfloor construction.
The standard maximum deflection allowed in the codes I'm aware of is L360. That means 1" in 360". This is the bare minimum standard for ceramic and porcelain tiles. Stone tiles require no more than L720 deflection. So your house may not meet this standard as is? You can still have travertine, but not with a regular thin set method, unless you can reduce deflection.
Other than that you need to know that most natural stone floors require lots more maintenance, cost more than ceramic and labor is also more.
However, the results would be really nice. Or....look for a porcelain look alike. Cheaper and much easier to live with.
Jaz
Old 01-25-2008, 02:02 PM   #3
Rewards Points: 150
Thanks Jaz for all this information. It really makes me reconsider my plan. Is ceramic and poercelain tile the same?. The badget is tight so I guess trivertine is out of question. Plus it requires more maintenance.
Old 01-25-2008, 03:31 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
In general terms both are ceramic, but porcelain is better in every way. I have porcelain that comes in sizes up to 36x36". Yikes that's big!!
Are you planning to do the work? Where are you?
Jaz
Old 01-27-2008, 05:03 PM   #5
remodeling pro
Poercelain is basically the same material fired at a hotter temperature in the kiln, which makes it more durable (harder), but also more brittle to work with. It was a commercial product that has filtered down to the residential market, and IMO is not necessary for residential conditions, but it is the new in demand flooring by HO's. Remember ceramic tile is like everything else, you get the quality you pay for; cheap ceramic is going to perform poorly over the long term.
Travertine is a soft stone and I do not recommend it for spaces that take hard use. It is best left to entry foyers and such IMO, but your limited budjet will take is out as an option anyway. There are a couple of ceramic/poercelains out there that are very good imitations of the real stuff, look around at different brands.
Also, the larger the individual tile, the more critical the flatness of the floor is.
troubleseeker is offline   Reply With Quote
Old 01-28-2008, 03:59 PM   #6
Rewards Points: 150
Jaz
I live in southern california. I would like to do the work my self but I just don't have the experience to do so. Most likely I will have to get a proffessional to get it done right the first time.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trivertine all thruout the house... or too much? gante Remodeling 6 01-25-2008 02:05 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
