Trimming Hardwood Floor Ends... - Flooring - DIY Chatroom Home Improvement Forum
Old 12-27-2007, 02:03 PM   #1
kemerick's Avatar
Rewards Points: 85
Trimming hardwood floor ends...
I installed my 5/8" thick bamboo hardwood flooring (glue down) and some ends do not have the 1/4" distance to the wall or tile. The question is, how should I trim the ends? I have tried an end mill on my Dremel and it just goes way too slow. Is the best tool to use something like this:
http://www.harborfreight.com/cpi/cta...emnumber=94626
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 12-27-2007, 04:48 PM   #2
kemerick's Avatar
Rewards Points: 85
I went and bought it and works great. It does not adjust for depth but that I managed to do with taping some cardboard to the bottom. One downfall is that if you do not hold it super tight, it will jump into the middle of the room tearing into your nice new hardwood flooring. Hopefully the threshold piece will be wide enough to cover it...
How to tell what hardwood... evane Flooring 9 09-06-2007 02:42 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 04:34 PM
old termite damaged hardwood Kbotard Flooring 8 05-14-2007 03:22 PM
