Trendy Finished Plywood Floors? Few Questions - Flooring - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By rusty baker
  • 1 Post By ChuckF.
  • 1 Post By joecaption
Old 12-12-2016, 02:02 PM   #1
Rewards Points: 12
Trendy Finished Plywood floors? Few questions
I am remodeling an attic to have a modern office space. I have subfloors (pine T&G planks). There are several holes in the T&G and the floor is bitten up, however I would love to save it if it was possible because it has its own character. The contractors who saw it, did not have the same vision and want to cover up. I am considering installing plywood 6"x8' staggered planks and finish them. The question is: 1) Which thickness of plywood? 2) Do I have to install any additional material between the sub-floor and the plywood? 3) Do I have to install crossing the subfloor?
I would love to post pictures but I do not know how.
Thanks for helping
kitui4u is offline   Reply With Quote
Old 12-12-2016, 03:47 PM   #2
Rewards Points: 14,010
Re: Trendy Finished Plywood floors? Few questions
Those pictures are very important!
What's "bitten up"?
I give up, what's 'plywood 6 X 8 staggered planks"?
Just does not sound like a great plan to me.
How would they be attached?
How are you going to stop them from flexing and squecking?
What happens when the top layer wears through?
There right, that old sub floor needs to be covered with 1/2 A/C plywood, then real flooring added over it.
Old 12-14-2016, 02:24 PM   #3
Rewards Points: 848
I'm going to assume the necessary homework was done to ensure this attic is reasonable structured for use as living space. If I read correctly, you're talking about ripping a sheet of plywood into planks and I cannot figure out why you would want to go to that effort over installing the plywood as sheets instead.
stick\shift is offline   Reply With Quote
Old 12-14-2016, 06:42 PM   #4
Rewards Points: 264
They are starting to do that in my area. Google some pictures. You'd be surprised at how nice those plywood floors can be. I've seen a few but can't tell you anything about the install. I've seen some where they burn the plywood before they stain and seal it. It's not for me but I could see in it an attic.
BayouRunner is offline   Reply With Quote
Old 12-14-2016, 06:59 PM   #5
Rewards Points: 264
This is just one of the nicer ones, just a random picture off the net. People are getter by pretty creative with it.
Old 12-14-2016, 07:12 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
They won't last long. The top layer of plywood will wear through in a short time.
Oso954 and Dave Sal like this.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-14-2016, 09:48 PM   #7
Rewards Points: 394
You'd have to carefully select plywood for your application, plywood is not generally made hard enough for a floor, it would show wear quickly from hard heels or furniture legs. Even if you chose 'hardwood plywood', that generally means a paper-thin veneer of good looking wood over a core of cheap not-very-hard poplar. Zero tolerance for any sanding.
You would have to face-nail it, and live with that or countersink and fill holes. Cut top edges would splinter badly until finished. Hard to predict how it would take stain.
Oso954 likes this.
ChuckF. is offline   Reply With Quote
Old 12-15-2016, 08:18 AM   #8
Please consider engineered or laminate flooring instead.
Oso954 likes this.
Old 01-05-2017, 08:18 AM   #9
Rewards Points: 12
That is exactly what I was envisioning. I do not have furniture in the space, if I scratch it...I will live with it. It is a modern attic office storage space. I have knew walls with built in cabinets, so no need for floor furniture. The concern is having big gaps between planks. Otherwise I would keep it because it has character. The floor was previously insulated with cellulose (the attic was not roof insulated before) and the cellulose is coming out of the gaps. Plus there are missing board pieces and wood knots. How can I attach pictures to this?
The Following User Says Thank You to kitui4u For This Useful Post:
abrowning (01-05-2017)
Old 01-05-2017, 10:45 AM   #10
Rewards Points: 394
Originally Posted by kitui4u View Post
...How can I attach pictures to this?
In the quick reply area below, there's a yellow rectangle with two little mountains in it. Click on it.
Old 01-05-2017, 11:48 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
The problem with plywood is that thin top layer....and it's soft.
It won't take long for it to get damaged.....and then splinters in the feet.
The only time pine has been used with any success on floors is when it's solid lumber.
How to care for finished concrete floors sarah c Flooring 2 04-06-2009 07:52 AM
Best way to fix poorly finished hardwood floors... skipjack Flooring 2 12-12-2008 01:20 PM
Getting wood floors finished. MyFeetReek Flooring 1 10-10-2008 09:08 PM
How to get paint off finished hardwood floors? BradG Painting 4 06-14-2008 07:14 PM
Finished Basement Remodel Questions bioguy Remodeling 6 11-15-2007 09:56 PM
