Travertine Over Gypcrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 09:04 PM   #1
travertine over gypcrete
hey guys and gals new member so bear with me
I have a 9' by45' closed in front porch that I have had radiant heat installed. After an 1 1/2" of gypcrete is poured over it can I install 18" by 18" travertine tile over it directly
toonafish is offline   Reply With Quote
Old 04-18-2009, 10:03 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
No, who the heck recommended Gypcrete for the job? Oh well, you can still install tile but need to use primers and or certain membranes. Didn't you ask about liquid membrane vs. Ditra? You need to keep all Q's about this project in one thread.
Jaz
Old 04-19-2009, 03:54 AM   #3
what do you suggest instead of gypcrete it's not a go yet I'm still negotiating
Old 04-19-2009, 08:44 AM   #4
ccarlisle's Avatar
I assume the manufacturer of the radiant heating system recommended the gypsum concrete so go with their recommendations. I also assume that these same people have confirmed that your porch CAN accept tiles like this and that all codes are followed, as well as having assessed that your subfloor system (whether wood or concrete) are suitable substrates for their product and can therefore warranty its installation.
That's alot of 'ifs' - but again assuming that has been done and you have the green light, then you're pretty much in their hands. This is not a piecemeal type of installation - everything must be considered - but I can tell you that you'll need a sealer over the gypsum concrete and under the uncoupling membrane but then again, the manufacturer will tell you which one, as well as indicate which thinset, typically modified will be needed as bond coat.
Which heating system are you putting in? did they recommend gypsum because it is lighter? just guessing.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Subfloor moves (wood) and want to install travertine scorpion693 Flooring 4 02-27-2009 07:38 PM
travertine floors Keith Carlson Ceramic Flooring 4 09-30-2008 12:41 AM
What Does Gypcrete Look Like? Janet Flooring 1 08-05-2008 10:51 PM
Laying Porcelain Tiles Over Gypcrete @ Lino Janet Flooring 11 07-30-2008 05:38 PM
