#1 |
Transitions in doorways--Allure Trafficmaster Vinyl Planks (not ultra)
Okay, so I know there is another thread about Allure TM VP, but it has over 600 replies so I am starting a new post here just about how to handle transitions between rooms.
At first I thought we could lay the ATMVP continuously through 3 bedrooms, an L-shaped hallway into a living space. But changed my mind about after reading here about the floors needing to remain "floating" and realizing the difficulty of the keeping the planks equal through a doorway into a hall...etc. I have the metal type of transition strip that can be used from same height to same height--drill into cement subfloor--make sure not to go through planks. But, somebody mentioned using an actual plank as a transition...please explain how to do that. thank you |
#2 | |
Transitions in doorways--Allure Trafficmaster Vinyl Planks (not ultra)Quote:
| Tags |
allure traffic master, doorway transitions, vinyl planks ![]() |
| Display Modes | |
| Trafficmaster Allure ULTRA! Planks | wiley0714 | Flooring | 176 | 05-05-2013 04:58 PM |
| Allure Ultra vinyl planks | gkschet | Flooring | 1 | 04-03-2012 11:48 AM |
| Allure Trafficmaster Vinyl Plank Storage in Garage? | ivorytower | Flooring | 0 | 07-06-2011 07:17 AM |
| Installing Allure vinyl planks | Needs advice | Flooring | 0 | 09-04-2010 05:59 PM |
| Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas | bennyjets | Flooring | 3 | 08-09-2009 11:50 PM |
