-   -   Transitions in doorways--Allure Trafficmaster Vinyl Planks (not ultra) (http://www.diychatroom.com/f5/transitions-doorways-allure-trafficmaster-vinyl-planks-not-ultra-110208/)
ivorytower 07-10-2011 06:53 AM
Okay, so I know there is another thread about Allure TM VP, but it has over 600 replies so I am starting a new post here just about how to handle transitions between rooms.
At first I thought we could lay the ATMVP continuously through 3 bedrooms, an L-shaped hallway into a living space. But changed my mind about after reading here about the floors needing to remain "floating" and realizing the difficulty of the keeping the planks equal through a doorway into a hall...etc.
I have the metal type of transition strip that can be used from same height to same height--drill into cement subfloor--make sure not to go through planks. But, somebody mentioned using an actual plank as a transition...please explain how to do that.
thank you
ttr13r 07-30-2011 12:07 PM
thank you
Those metal transitions look hideous (I think so anyway) Call Halstead customer service, they should be able to help you.
