Transition To Uneven Rustic Slate Fireplace - Flooring - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 11:05 AM   #1
transition to uneven rustic slate fireplace
Hi...I'm looking for some ideas on tranisitoning from our porcelain 12x24 tiles to our fireplace. The issue is that the fireplace is very rustice with big pieces of slate so the edging is uneven, Does anyone have any flexible suggestions?
Marusha is offline   Reply With Quote
Old 07-28-2011, 03:59 PM   #2
a picture would help. any chance you could take a grinder and cut a line just above where the surface of the tile will be so they slide under a little? are you butting the tile to the hearth? is the hearth raised?
slate walls timbo59 Building & Construction 5 12-06-2010 09:46 AM
Uneven hw floor to vinyl transition joemontana16 Flooring 0 03-10-2010 10:10 AM
Slate Fireplace JackOfAllTrades Tiling, ceramics, marble 11 01-03-2010 01:10 AM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 04:58 PM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 08:22 PM
