Are Transition Pieces Required? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 09:01 PM   #1
Are transition pieces required?
I'm interested in Triangulo's 5" Brazilian Pecan Coffee and going to install it in my great room, stairs and bedrooms. I want it flush to the existing tile floor in the kitchen and bathrooms and do not wish to install transition pieces. Is it possible? Am I limited myself to certain installation method - Floated or Glue-down? I'm also confused by the transition piece requirement. I was told that I can avoid using transition pieces but to use silicon based chalking then my manufacturer warranty won't be void. Is that true?
Thank you very much for your help!
tsquared
tsquared is offline   Reply With Quote
Old 07-30-2013, 09:28 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
You need transition pieces. All wood or laminate flooring expands and contracts with humidity and/or temperature change. If it can't move, it will buckle or split.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 07-31-2013, 05:21 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
And if it does have issues the manufacturer will drop all responsibility in a heartbeat if you didn't follow their installation guidelines, even if the claim in completely unrelated.
Darkling Designs
poppameth is offline   Reply With Quote
Old 07-31-2013, 06:22 AM   #4
Rewards Points: 13,694
Have you gone on line and printed out the install directions from the manufacturer?
Have you contacted them and gotten permission in writing to do it your way?
There the ones going to be warrantying this not
a bunch of strangers on the net.
I agree with the other poster about the need for the strips. Only place I could see using caulking is if for example if the flooring was run parallel to an outside wall, past an exterior door where it meets the threshold.
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 6 11-27-2013 09:56 AM
ceramic tile transition to laminate Kman92592 General DIY Discussions 1 07-01-2010 09:55 PM
laminate room transition - expansion joint req'd? rtoni Flooring 9 06-02-2010 10:19 AM
1/4 inch gap at the transition? zman22 Flooring 1 03-29-2010 08:15 AM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
