Transition Piece Required?? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-24-2008, 12:06 PM   #1
I am installing a hardwood floor around an existing ceramic tile hearth (67" long, same height as the wood flooring) in front of my fireplace. The wood will be running parallel to the 67" span. I would like to use the wood flooring to make a mitered frame around the hearth rather than using a transition piece, can I get away with not leaving the 1/2" expansion gap around the tile? I don't really like the appearance of the transition pieces and would prefer a smoother look. The width of the room is 13'.
John S is offline   Reply With Quote
Old 09-24-2008, 08:11 PM   #2
As a carpenter with 35 years experience I think as long as you leave room for expansion at the walls you should be ok. Also I agree that a mitred frame around the hearth would look great.
Double D is offline   Reply With Quote
Old 09-25-2008, 01:24 PM   #3
any way you can post a pic I would like to see what your doing Thanks
clasact is offline   Reply With Quote
Old 09-25-2008, 02:37 PM   #4
Double D - Thanks for your input.
Clasact - Thanks for the reply, here are a couple pictures.
John
Old 09-25-2008, 02:47 PM   #5
that looks pretty good like the contrast I may try it myself Thanks for the pics
Old 09-25-2008, 06:39 PM   #6
Floorwizard's Avatar
Wow. good lookin floor.
Floorwizard is offline   Reply With Quote
Carpet/Linoleum transition Crashz Flooring 2 07-17-2008 04:37 PM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 03:19 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 06:25 PM
Need some transition moulding advice... confused Flooring 4 08-24-2006 05:35 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 11:12 AM
