Transition From Permastone To Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 10:09 AM   #1
Transition from permastone to hardwood
We had permastone installed in our kitchen over sheet vinyl. The installer wanted to put a metal strip as the transition between the kitchen and the hall which is hardwood. I didn't want that so he used the old threshold and made it thinner to compensate for the new height difference. As you can see, it looks bad and is a trip hazard.
What can we do? I looked at new hw reducer transitions at Lowes, but they are very thick. How thin can we make the transition without it cracking? It seems to be a 3/8" difference between the floors as it is now. There must be something we can use. Most likely we'll do it ourselves as this guy said this is the best he can do.
Thanks.
bedelia is offline   Reply With Quote
Old 05-10-2010, 04:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That guy is a hack! I can't believe it when installers take the path of least resistance and dump on their customers like he did you.
There are mouldings available both unfinished and pre-finished but you may have to go to a real flooring store to find them.
You could have that piece you have there now planed-down with a taper. Taper it to 3/8" X 1/8" and you'll be fine. It would have to be stained of course.
I think Durastone (isn't that Durastone) has a reducer to match that pattern available also.
XXX
Old 05-10-2010, 04:40 PM   #3
It's not the same as Durastone (not sure they make that anymore). It's Permastone by Tarkett, a vinyl tile. I'll check out some stores.
I'm waiting for him to return my call since now a tile is popping up. What next.
Old 05-10-2010, 05:01 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK, I thought "Permastone" was the stuff you put on the exterior of a house to make it look like stone. My bad.
XXX
Old 05-10-2010, 06:04 PM   #5
i had a floor like that. installer called it a day and left it just like yours. course i get the tricky part and not the whole job but thats ok anyone can do the easy stuff. i took a couple of pieces of their hickory flooring and with a table saw and sanders was able to make a tapered t&g piece to fit their floor. time consuming with adding in clear sealer but looked sharp and easy on the feet
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
bedelia (05-11-2010)
Hardwood over OSB & transition issue janralix Flooring 4 05-02-2011 11:29 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
Hardwood Floor to stone Transition - how? water_cutter101 Flooring 3 03-05-2009 04:51 PM
Transition from Tile to Hardwood anthony9887 Flooring 1 04-18-2008 11:51 PM
