Transition Molding Fit? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 10:52 PM   #1
Rewards Points: 81
I am ready to install the transition molding between the carpet and click lock laminate flooring. The transition molding hits the wall right at the door casing. Should I cut the profile of the casing into the end of the transition molding (the red line) or just an angle (the green line)?
Transition Molding Fit?-dscn2848.jpg   Transition Molding Fit?-dscn2849-options.jpg
OhioDon is offline   Reply With Quote
Old 12-24-2013, 02:27 AM   #2
Rewards Points: 13,964
Why the super wide transition?
If your going to use that one I'd mark the casing and cut the case with an oscillating saw so the it can slip in under the case so you do not see the ends of the transition.
Old 12-25-2013, 12:04 AM   #3
Rewards Points: 236
that depends. if you can profile it, then do it. if you have doubts, or are not too picky, then cut it straight. if you do cut it straight, it will not look as good. but its a little molding. in a week you will forget about either way you did it.
pick your battle.
Fix'n it is offline   Reply With Quote
Old 02-10-2014, 07:35 PM   #4
Rewards Points: 81
I thought I would come back and show everyone what I did. I used a utility knife and a file and just keep playing with it. I'm not sure how long it took but it's good I'm not charging by the hour. Actually, I wish I was getting paid by the hour! lol!
Transition Molding Fit?-dscn2852.jpg   Transition Molding Fit?-dscn2850.jpg   Transition Molding Fit?-dscn2851.jpg
The Following User Says Thank You to OhioDon For This Useful Post:
Fix'n it (02-10-2014)
Old 02-10-2014, 07:47 PM   #5
Rewards Points: 236
Trying to remove base molding h22lude Flooring 3 05-29-2013 12:59 PM
Tile to Molding Transition joshy Flooring 2 10-25-2011 08:51 PM
How to handle crown molding transition to kitchen cabinets mystic_cobra Carpentry 6 09-15-2011 02:37 PM
Crown Molding Transition over narrow gap between ceiling and window top ... NallaChiruta Carpentry 4 02-11-2010 07:34 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
