Old 03-17-2009, 12:17 PM   #1
Default Transition laminate to higher fireplace tile
I am installing laminate flooring. I have a fireplace with tile around it that sits about 3/4-inch higher than the subfloor. We have some "hard surface reducer" trim pieces, but the reducer is not tall enough to clear the edge of the tile.
What would be the best way to install my transitions?
My thought is to cut a thin strip of wood, nail it to the plywood subfloor and install the trim track on top of the strip. This would raise the height of the transition and allow me to install it transitioning down toward the laminate. (Thin side of the transition over the tile, thick side over the laminate).
Any other suggestions?
Thanks.
Slippin is offline   Reply With Quote
Old 03-17-2009, 10:22 PM   #2
Sounds like you've got it covered... make sure to leave an expansion gap between the piece of wood you use to lift the track and the laminate.
Mudd is offline   Reply With Quote
More On This Topic
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. In this instance a minimum two courses of lower roof panels are laid through. If possible with continental tiles, lay it out so that the lower part of... Read More »
How to Frame Roof Valleys
How to Frame Roof Valleys by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. It is important to maintain even tile courses each side of a gable and a roof wherever possible when using burrow trims. Uneven length trims cut at... Read More »
Hi, I'm Betty Ingham and I'm speaking on behalf of Expert Village. When we moved into this house over 8 years ago someone had just put concrete in the bottom of this fireplace. The mantle was painted many, many colors and so once we stripped out all the... Read More »
Many outdoor fireplaces are fancier than indoor ones. Some expensive fireplaces stand over eight feet tall and include MP3 docks. Less fancy ones are just a metal bowl with legs. Almost anyone can afford an outdoor fireplace because there are many styles... Read More »
Fireplace Safety Tips
Fireplace Safety Tips by Expert Village
Hi! I'm Bobby on behalf of Expert Village. In this series, I am going to show you several different ways that you could easily light a fire within your fireplace and I am going to show you several safety techniques or things that you need to be aware of... Read More »
Fireplace Lower Than Laminate jonathan03 Flooring 1 12-30-2008 08:31 AM
Replacing tile with laminate - Bad idea? Regina Phalange Flooring 6 11-22-2008 08:12 PM
tile to laminate transition SML93 Flooring 5 03-22-2008 07:11 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-21-2007 12:44 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 04:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
